Author Topic: DarkRED  (Read 187262 times)
silvestreccf
The best skim ever!! this should be the original interface of this music player, people today wants something like Deezer interface, Metro, Itunes store interface, I would like to konow how to make skims, I'm a desiner, I got so many ideas, but I dont know how to began...
silvestreccf
More clean than this, impossible. The only thing I didn't like , was the compact player color, to much red, you should keep Grey light and dark in mind.
What about a White or light grey version. kind a Asylum version that is a very good skim.
endeavour1934
I don't know what's wrong with the skins, but with MusicBee 2.3 covers don't appear on the main window when using the artwork view
Anyone can help?
all fine for me, perhaps you can post a screenshot in a separate topic and explain what had been changed when it started happening
Last Edit: December 06, 2013, 06:06:17 PM by Steven
silvestreccf
Anyone can help?
2.3? are we in 2.2 Musicbee?
there is a bug with v2.3 where in certain circumstances it wouldnt show 1 picture for the album and tracks layout. That should be fixed with this patch:
http://musicbee.niblseed.com/V2_3/MusicBee_Exe_Patched.zip
endeavour1934
Still not working for me, on 2 different computers.
Screenshot (1) right after opening MusicBee (2) when I move the cursor around. http://i.minus.com/jmmn3Kpkbx0OZ.jpg
Only happens with my skin, so I'm guessing that it's my fault for reordering some of the elements inside the xml skin file. But in 2.2 it worked perfectly.
i can reproduce this now with your skin. Its due to the UseArtworkBorders setting (as a side note your picture border has only a very tiny difference in colour to the panel background)
This should fix it:
silvestreccf
Bug  Hover effect in the buttons of the MiniPlayer!! see link below.
this is the perfect skim thanks for sharing.
https://www.dropbox.com/s/vvuchwfyed295sb/eFEITO-HOVER.jpg?m=
mikebo
This is a really great looking skin, if it's not included by default it definitely should be.
Maybe it would be worth checking out variables to make different color variations. It would take slightly more work with the bitmap version though.
One issue i found was with "Content[TrackDetail].ListAlternating.Disabled" fg color not matching "Content[TrackDetail].Body.Disabled"
which for example makes a list of not downloaded podcasts look like this:
edit: Also the Previous Track button in bitmap skin moves 1px to the left when highlighted.
Last Edit: December 12, 2013, 08:44:48 AM by mikebo
endeavour1934
I know that bug, but I can't change it without change the button color on the preferences panel. :(
Thanks for noticing those! By the way, your Dusk/Dawn/Midnight skins should be the default ones for MusicBee, they are amazing!
About color variations... I had in mind using some from the Windows Phone palette:
Any suggestions?
Last Edit: December 26, 2013, 05:33:27 PM by endeavour1934
i will change it so the setting doesnt conflict
