Author Topic: Dark Energy  (Read 24643 times)
Space Octopus
  • Teach a Man To Reason, He'll Think For a Lifetime
I LOVE it!!!!!  ;)
Make it so, number one.
Iasc
A new version for Musicbee 3 has been added. The new version will not work with any Musicbee version before 3.0.
See first post for link.
  • MB Version: 3.6.8878 P
I thought you might have overridden the maroon panel in Now Playing/Compact Player to blend more with the dark blue (or contrast better)?
Still one of my favourite skins :)
Iasc
I don't know how i missed that. Made the change and updated the link.
Much better.  Thank you.
Iasc
Updated. Several fixes and changes.
Azazelice
Hey bro, digs the skin, only have one issue though. the Album cover border is white, can I change the element for "Controls.ArtworkFrame", please advice (for a more darker look)
thanks in advance.
 \m/ :)
thanks in advance.
 \m/ :)
Not if the skin is a bit-mapped skin (ends with .xmlc) which I'm pretty sure this skin is.
Azazelice
figured as much as I tried to edit the .xmlc file and it looked like Cuneiform  :)
Iasc
thanks in advance.
 \m/ :)
Made a change. Re-download and let me know what you think.
JH1
Hey iasc what are those and how can i turn them on?
JH1
and i quite like ur layout can u post ur settings
Adson
Thanks a lot for this great skin  :)
There is only one little detail that I find somewhat difficult:
The handles (or drag points) of the scrollbars are nearly unvisible with standard monitor settings (at least on my machine).
Is there a chance to make them a little bit brighter?
And BTW: Is it possible to edit the xmlc file somehow, so that the user self could set the colors according their tastes or needs?
Thanks in advance for your help.
Iasc
Updated with new skin elements and some fixes.
