Author Topic: Google Play Music inspired skin  (Read 13457 times)
JMoss
Google Play Music meets MusicBee
Hey everyone!
Having an Android phone, I'm using the Google Play Music application almost every day.
Recently I thought to port some of its visual traits to MusicBee to obtain a sort of continuity.
Below you can have a look to the result: a vivid orange, still elegant (I hope!) skin.
Also, you are free to download and reuse the sources  ;)
Skinned Borders
Windows Borders
DOWNLOADS
GPlay Music Skin
SOURCES
Last Edit: September 07, 2013, 12:12:08 AM by JMoss
Wonderful work! Thanks for sharing this!
BTW I just happened to notice a glitch since I was using menu bar below caption bar.
With skinned borders, switching from "menu bar below caption bar" to "caption bar (button)" leaves menu bar separator drawn over main player docked on the top. Probably the line comes from:
<element id="MenuBarSeparator" bg="208,107,49" />
But I don't know how to fix it, except restarting MB, since I've never worked on bitmap skins.
  • MB Version: 3.6.8849 P
Looks very good
...but no AutoDJ in player bar
beeing good
This is really nice JMoss, I like the off-white and the orange, makes it very easy on the eye.
de.cayed
I don't usually like the color orange, but I'm really loving this skin~
Looks very good
Fixed  ;)
Thanks for fixing  :)
Too nice a skin for me not to use
Pat
Really nice skin.
I notice - on my computer - that the time indicators (time played / time remaining) left and right of the progress bar are not exactly positioned on the same height of progress bar. The time indicators are offset a bit below the progress bar line.
