Author Topic: Purple Haze  (Read 12024 times)
Iasc
Purple Haze
Updated for MusicBee 3
INSTRUCTIONS
[2] Unzip it in the MusicBee Program Files/Skins
Icons designed by endeavour1934.
Last Edit: October 02, 2016, 07:56:38 AM by iasc
Nice!  Purple happens to be my favorite color...
Iasc
Updated.
just a few minor fixes.
Iasc
Updated for musicbee 3. See first post for details.
Iasc
Iasc
JH1
how to make visualiser look like that , does anyone know?
mine doesn't stretch like this
Coogan
Updated with some minor fixes.
Where is the updated Purple Haze?
I clicked the link in the first post, but mediafire says that file was last updated on 2016-10-08.
Really like the skin.  Thanks a lot.   :)
Coogan
My MusicBee Version:
3.5.8842
MB 3.0 was available long before Oct 2016 and skins made with 3.0 in mind will work on 3.1.
Have you downloaded this and tried it?
Coogan
Yes, I downloaded the file from October and it's working good.
I only noticed that Iasc posted on March 5th that there were some minor changes, so I thought the skin had recently
been updated.
Coogan
3.5.8842
If what you downloaded was after March 5 you probably have the minor updates. Typical behavior of those who create skins is to keep the link the same even though the file has been updated.
Iasc
Updated with new skin elements and some fixes.
